Add on activation time
JW2
If I add data add in the middle of my 30 day cycle how long does it take for data to activate on my phone
@Fakeittilumkei wrote:
Turn your phone off then back on again and make sure you have data roaming turned on. Usually activates within a couple minutes.
Data roaming does not need to be enabled for in-Canada data add-ons to be used in Canada.
Fakeittilumkei
It will be there are soon as you make the purchase.
sunflowershine
@JW2 it will be immediately after you get the add-on.
