08-18-2020 11:06 AM - edited 01-05-2022 12:35 PM
08-18-2020 11:38 AM
08-18-2020 11:12 AM
@Eurydice , as already mentioned, there are no refunds with this service. However, you should reach out to the moderator team for some goodwill. The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. If use of smartform brings no joy, then use the following direct link to private message the moderator team. Refer to the following knowledge base article for additional information on the moderator team. Good luck!
08-18-2020 11:10 AM
@Eurydice PM is A prepaid there are no refunds. However, contact the moderators, explain what happened and ask them nicely for a credit. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-18-2020 11:09 AM
PM is prepaid so no guarantee of a refund but you could try submitting a ticket to a moderator by clicking on the question mark on the bottom right.
