Add on US data not working
Osotua
Hi added us roaming. Roaming data no working. Requesting for refund $ 20 pr considering switching to other reliable cellular providers.
9 REPLIES 9
Osotua
Already tried restarting phone on the very first day of adding data. Not worth troubleshooting considering I have only one mor day in the US
@Osotua it was within 10 days that you successfully added the Roaming addon to your account, was it?
Try restarting your phone or do a reset of the device's network settings, to help get connected to the proper network.
Get Help Article for Roaming and things for reference:
https://www.publicmobile.ca/en/bc/get-help/articles/us-roaming#:~:text=Troubleshooting%20U.S.%20Roam...
darlicious
@Osotua
What's the make and model of your phone?
@Osotua you meant you cannot use data at all there?
make sure you enable Roaming Data.
you tried both T-Mobile  and AT&T  and neither working for you?
Osotua
  • Am in the US for three days - only one more day to go and no data 🤔
Just checking...are you in the USA @Osotua . Roaming addons are for use whilst in the USA.
All other addons are for use whilst in Canada.
dust2dust
@Osotua- Did you try to manually connect to T-Mobile? Did you turn on roaming data? Maybe have a go at trying AT&T as well. Did your normal data work when you were at home? Data should theoretically work.
darlicious
@Osotua
Read the link post with info on Public mobiles US roaming add-ons. Make sure you follow the instructions on how to make sure the roaming add-on will work and the limitations to voice services. If you need more help or troubleshooting after you implement the methods needed to ensure your US roaming add-on will work we can help you. then.
While customer support are very willing to give credits where credit is due technically all purchases are non-refundable and they will not credit your account if you do not try to get your US roaming to work and if you plan on leaving a credit will not help you.
https://productioncommunity.publicmobile.ca/t5/Get-Support/US-Roaming-Add-ons-Decommissioning-of-US-...
RossN
@Osotua hi if you would like a refund/credit
you need to contact a customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
