07-12-2020 02:54 PM - edited 01-05-2022 12:25 PM
Hi!
I just ran out of minutes while I was talking on the phone.
I've logged in and added more minutes. I think it has all gone though ok, however I can't make a call yet.
I'm wondering how long it usually takes for the add ons to take effect.
Thanks for your time.
07-12-2020 03:10 PM - edited 07-12-2020 03:12 PM
@jeav Just repeat the process oftof purchasing the add-on to complete step two so that you can make calls again.
07-12-2020 03:00 PM
@jeav Do you see it in the list of your account now? Should be there after purchase right away. Relogin your account.
07-12-2020 02:56 PM - edited 07-12-2020 03:02 PM
@jeav around 5 minutes. Did you actually buy the add on? Or just deposit the funds? If you see the funds sitting in your self service account. Then go here and buy it. Stay safe.
07-12-2020 02:56 PM
It should be immediate. Do you see the long distance add on in your self service account? Buying any add on is a two step process. Load funds and then purchase add on.
If you see the add on, maybe rebooting your phone will help.
