12-02-2021 11:18 AM - edited 01-04-2022 05:04 AM
I purchased add-Ons for U.S use
but it doesn’t work I can’t use my phone in U.S
12-02-2021 12:15 PM
For US Roaming 10 day packages
Unlimited U.S. Talk, Text and 250MB Data Bundle = $20
Unlimited U.S. Talk and Text Bundle = $15
Unlimited U.S. Talk Only = $8
Unlimited U.S. Text Only = $8
U.S. Data Only 10 day packages
250MB = $10
500MB = $15
1GB = $20
sign in to Self-Serve, to review your account, if you found at Available Funds: $$
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
- Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
- Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
- When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
- You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
- If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
- Select ‘Confirm my purchase’, and you’re off to the races!
after you Add-on you have to do Rebooting your phone
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link..
and you can try select manual network settings
12-02-2021 11:28 AM
US Roaming6
U.S. Talk, Text and 250 MB Data bundle: $20
U.S. Talk and Text Bundle: $15
U.S. Talk Only: $8
U.S. Text Only: $8
12-02-2021 11:23 AM - edited 12-02-2021 11:25 AM
@Safa51 wrote:I have 1000/roaming U.S but my phone doesn’t work in US
1000? do you have the 1000 US Long distance minute instead? The 1000 minutes is a US Long distance call to use when you are in Canada.
you need to check the Add-ons that say Roaming and buy those
US Roaming Text - $8
US Roaming - Unlimited talk (10 days) - $8
US Roaming - Talk Text (10 days) $15
US Roaming - 250MB Data (10 days) - $10
US Roaming - 500MB Data (10 days) - $15
US Roaming - 1GB Data (10 days) - $20
US Roaming - Talk Text 250 Data (10 days) $20
12-02-2021 11:22 AM
@Safa51 : You bought the wrong add-on. It doesn't say roaming. You need the ones that say roaming.
12-02-2021 11:21 AM
12-02-2021 11:20 AM
Was it your first add-on purchase or subsequent.
There should be 24 hours gap since the previous one expires.
Contact Support and create a ticket.
