Add-Ons
RapNugget
As of May, I have never received my paid add-ons, which was the 250Mb plan.
Staliger
@RapNugget Are you sure your Autopay is enabled? If it is, the 250mb of data should be on your account.
geopublic
@RapNugget  Public Mobile offers two data add-ons (Used within Canada) 1GB for $15 and 200MB for $10. Public offers as US Roaming 250MB data add-on that can only be used within the US. Which one did you purchase?
Note purchasing a data add-on is a two step process.
  1. Add the funds to your account
  2. Purchase the add-on
Check you account balance to see if the amount is still there.
popping
@RapNugget
If you have the $15 plan, you will get the bonus 250MB data if and only if your enable the autopay.  You may setup your credit/debit card on your account.  Double check again to make sure that you had enabled the autopay.
Refer to the bottom of your overview page - Autopay section for details.
Have a better and better days!
JoyLuck
There is no paid add on of 250 MB.
Are you on the $15 plan on autopay which would give you 250 MB?
Check self service if on the $15 plan it should look something like this unless your data has been used up then it will not appear. You can then check your usage history in self service.
