Add On
Greyhound
I purchased an add on for 500 minutes in Canada. The amount was taken from my credit card. I have not gotten the 500 minutes in my account
Yes, it does. You’re good to go!
And the best thing about these add-ons @Greyhound  is they never expire until they are fully consumed.
@Greyhound  Yes it will only get used once you plan mins are used up and the add on will roll over till you use them all up
Greyhound
The my account screen is somewhat confusing. In my account displays the following.
Left hand side says
Plan Usage
Current Plan Cycle: Jan 12, 2023 - Feb 11, 2023
Minutes Usage
100 Minutes Canada-Wide Talk
96.00 mins used
4 mins left
Add-On Usage
0.0%
500 mins
500 min Canada-Wide Long Distance
500 mins left
The right hand side says
Add-On Usage
0.0%
500 mins
500 mins left
Does that mean I do have 500 minutes when the 4 minutes are used up?
@Greyhound  Try this
Check add-ons /mins /Data
dabr
@Greyhound   Try refreshing your account page with the little refresh icon bottom right or login with incognito/private mode or another browser as you're probably seeing old info due to caching issues with PM's self serve account.
