07-14-2026
06:49 AM
08-15-2026
11:23 AM
Dunkman
Hello,
I have existing non-expiring data. If I purchase add on data from Public Mobile will it use it first or my existing non-expiring data?
Thank you
07-14-2026 09:24 AM
A fair question? My non-expiry data is getting low, if I knew it wasn’t going to be used first, it would be a nice backup since I won’t lose it. However, if it is going to be used before any add-on, I’ll use it up first.
07-14-2026 08:35 AM - edited 07-14-2026 09:35 AM
why would you do that if you still have data to use?
I wouldn't suggest you to buy data addon if you still have other non-expiring addon. you have no control over which addon to use first, and if the paid addon with 30 days expiry does not use first, you would be wasting your money.
We only know this:
We do not know the answer if you have other addons in the mix. And I would suggest you to drain your bonus data first before considering buy data addon. And when buying data addon, only buy enough to be used from the date to the end of the next cycle and not to buy more data just because it is cheaper per Gb
