Active plan
Mac84
I have a 40$ a month plan but I try making a call and it says I have no active long distance plan. It's canada wide. How do I fix this
11 REPLIES 11
geopublic
@Mac84  Make sure you account is active by dialing 611 and also make sure you are dialing the correct area code
@RosieR
Yeah...not very correct....
AE_Collector
@AE_Collector wrote:
@computergeek541 wrote:
@Jb456 wrote:
Let the message play out then it should connect the call or put a 2 infront of the number.
Does that work?
A 2?
Yes, should be a “3” for Public Mobile. Koodo dials “2” and Telus “1”.
AE_Collector
@AE_Collector this is correct?  Wow!  I learn new this everyday.  😊
Does that work?
A 2?
AE_Collector
You of all people would know darn well that this is a Canada/US country code. Ain't nuttin' to do wid the carrier. 🙂
@Jb456 wrote:
@computergeek541  I fixed it. You know was just rushing incase you move the thread and I get the red screen again 🤣
You know that I was just kidding.It's really easy to type something incorrectly when the two keys are beside each other.
Does that work?
A 2?
AE_Collector
Does that work?
A 2?
AE_Collector
Try dialing 1 and then your number. While you have a Canada Wide plan, not everyone else using the network does thus the Long Distance message. Areas are still divided into local calling areas from the land line age and a 1 signals that you want to call outside the local calling area a wider area and since YOUR plan includes this you wont have to pay extra.
AE_Collector
The first thing to do is to make sure that the number is being dialed correctly.  Although it should not matter (calls should still go through anyway), there have been some reports of some calls not proceeding unless a 1 is dialed before the area code.
Jb456
Let the message play out then it should connect the call or put a 1 infront of the number.
Does that work?
