Activation
Corey77
I have 31$ in my account but phone still doesn’t work,my plan is 28&/month.
@Corey77  - just adding funds does not activate a plan or provide a service you may be depleted of.
Are you a new customer, or an existing one that your services do not work all of a sudden?
If your account status is Active, try:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*perform a reset network settings on your device
*try your SIM card into another compatible phone...this could rule out a device issue/setting.
*manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) for dropping or unable to make incoming/outgoing calls
*Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
If your account is Suspended, see other posts.
@Corey77
Try rebooting your phone by powering it off then reseat your SIM and see if that works.
benfatto
 @Corey77  I think that if you have autopay with a valid card, or paid in full, but have no service, you likely need assistance from the moderators.
To get a ticket click https://widget.telus.tiia.ai/publicmobile/publicmobile.html and enter your question into SIMon. To confirm your ticket has been submitted, check the SENT box in your private messages; click the small envelope beside your avatar at top right on your screen.
Yummy
When was your renewal date?
You should see reactivate button if your account was suspended and you recently added funds.
You might try to manually add $1 (as 'other') and reactivate button should appear or it will automatically reactivate.
Sometimes log out/in from account might help.
hairbag1
Log in to your account..is the plan Active  ?
@Corey77   is there a button Reactivate my plan around?  click on it and see what it says
If that does not work, try it in Incognito mode or use another completely different browser (Edge/Firefox/Chrome)
