04-20-2022 01:27 AM
Hi Everyone, just activated my sim. I am able to make calls but I can't receive calls. I can't send or receive texts as well. Please help.
04-20-2022 10:01 AM
Did you open a ticket with a CSA and were they able to resolve this for you?
04-20-2022 04:23 AM
Your SIM card only partially provisioned to your account. It's likely only customer support can provision it properly since the phone number isn't being recognized. But there are a few things you can try in the meantime.
Still no joy? If you have already reached out to customer support via the links supplied by @JoyLuck then expect a reply an hour or two at most after they open for business in the morning. Keep an eye on the envelope icon next to your avatar at the top right corner of your screen for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times but expect a reply in the morning
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
04-20-2022 02:05 AM
If all your services are not working by the morning then I would suggest contacting a CSA.
Customer Support Agents are available:
04-20-2022 02:02 AM
I did enable sms on the messaging app. I can make calls on the PM sim but I can't receive calls from it. It says ""The number you have reached is not in service. Please check the number and try your call again."
04-20-2022 01:55 AM
04-20-2022 01:50 AM
I did try all of these but it's still not working. I'm still able to make a call, (other phone would ring, and I can make conversations) but when the same phone calls my phone, it says "The number you have reached is not in service. Please check the number and try your call again." Weird. Also still unable to send and receive text messages.
04-20-2022 01:43 AM
Try the following:
-Reboot
-Reset Network Settings and reboot
-Put on airplane mode and then take off and reboot
04-20-2022 01:40 AM
I didn't port any number from other providers. This is a new sim and new activation. Yes, I'm using an iPhone.
04-20-2022 01:35 AM
@Jean1957 wrote:Hi Everyone, just activated my sim. I am able to make calls but I can't receive calls. I can't send or receive texts as well. Please help.
It's possible that there are multiple issues here. Did you ask for a number to be ported in to Public Mobile? Not recieving incoming phone calls nor incoming text messages is an indication of number porting that isn't complete. If you did request that, reinsert your old carrier's SIM card to repond to a text message from them that authorizes the phone number transfer. As for the inability to send text messages, that would be some other type of issue. I would suggest that if you're using an iPhone device to ensure that you have the SMS feature enabled.
