08-14-2023 11:39 PM
I just keep getting into a loop of signing int my account when trying to activate a new SIM
My Account
09-01-2023 10:48 PM
ive deleted and re-installed it on my phone 3 times now. but i will try again thank you
09-01-2023 10:47 PM
Try deleting and then re-downloading the app. Unfortunately the app is requirement for activation so there is no way around it
09-01-2023 10:46 PM
everytime i put my credentials in on the app, it gets stuck at a blank page
09-01-2023 10:45 PM
the app is worse.. it doesnt even let me login. once i put my credentials in on the app, it gets stuck at a blank page immediately everytime..
09-01-2023 10:43 PM
what error message you got? are you using the app to activate?
09-01-2023 10:43 PM
Sorry to hear you are having issues trying to activate. Are you using the app? Activation requires you to use the app. Desktop will only allow the process to go so far before you just get a login loop. Download the app and login when prompted once you open it, it should allow you to go through the rest of the activation process.
09-01-2023 10:34 PM
ive had the same issue for a week now..... wont let me login to activate my sim...
08-14-2023 11:54 PM
probably wrong timing, My account down. Try again later to complete the activation
08-14-2023 11:42 PM - edited 08-14-2023 11:43 PM
Unfortunately the website is experiencing some unexpected downtime this evening. If this isn’t urgent I would suggest trying again in the morning to complete the activation process.
