12-15-2023 04:22 PM - last edited on 12-15-2023 05:21 PM by computergeek541
I am a new customer and I tried to signup for $34 for 50gb. The payment went through but got an error and currently, it's stuck at Step 3.
12-15-2023 05:20 PM
Sorry, my mistake on that. It's $34 for 40Gb. I paid $40.95 including tax and physical sim card to be shipped.
12-15-2023 05:07 PM
@Cruz I see a $34 for 40gb in Alberta but not 50gb. The $34 for 50gb seems to be Quebec only. I don't know if that could be the cause of your problem.
12-15-2023 05:04 PM
I am in Alberta
12-15-2023 04:56 PM
@Cruz Are you in Quebec? That plan isn't offered in the other provinces, or at least not in BC, NS or ON.
12-15-2023 04:25 PM
Hello @Cruz,
It sounds like you encounters a technical issue that might need to be resolved through submitting a ticket as outlined in your screenshot. It will likely be an easy fix once you submit the ticket to customer support.
You can do so by using the following link:
Please be sure to explain the issue to them. They will respond to you in your community inbox so check it from time to time.
12-15-2023 04:24 PM
@Cruz Please submit ticket with support
send a private message To CS_Agents
