10-23-2023 11:36 PM
Helping a family member activate a SIM. All is well until the final step, where I need to enter a 6 digit code sent to the number I'm trying to activate. Real chicken and egg scenario.
Any help would be dandy,
Thanks
10-24-2023 09:36 AM - edited 10-24-2023 09:37 AM
Are you trying to activate a physical SIM card or an e-sim?
To contact a Customer Support Agent, send a private message to Customer Support Agent by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
10-24-2023 08:53 AM
Thanks for your help. Part of the problem I think is the phone is too old to download the app, so we used the app on a different phone. It actually said everything was activated, but the phone still says "unregistered SIM", and trying to log in to the account the SIM is connected to now is impossible because we can't receive a text.
10-24-2023 05:49 AM
Is there an option provided which reads "didn't get the code?"
When you tap that does it give you the option to send it to an email instead?
10-24-2023 12:46 AM
are you using the app to activate? If not, please download and use the app to complete the activation
And are you activating eSIM or physical sim? If physical sim, put the sim in the phone and see if it got the codes
If not, can you post a screenshot of which step you are at on the Subscription process?
