05-29-2023 08:54 PM - last edited on 06-11-2023 11:36 AM by Dunkman
Entered SIM card, paid, chose a number. Now Eversafe says I have an account and sends the Verification code to the new number but I dont receive it!
05-30-2023 03:32 AM - edited 05-30-2023 03:34 AM
Hi @Amanda21, it looks like you are using an Android and the Android Messages (text) app might be associated with the previous phone number you had on that phone. Check to see if your Chat Features (RCS) is enabled and if it's associated with the previous phone number turn off the chat features. I had issue when I had a new number and wasn't receiving texts and I had to turn off Chat features via the message app setting options and clear the cache and storage.
If you need step by step instruction, Google: How to turn off RCS chats.
05-29-2023 09:16 PM
HI @Amanda21
Please message CS agent here:
05-29-2023 09:08 PM
Just tried this
Didnt work
How can i start a support ticket?
05-29-2023 09:05 PM
@Amanda21 wrote:
@Amanda21 you see the resend code. You might clicking on that does not give you that option? did you try the workaround suggested by @hTideGnow above?
05-29-2023 09:03 PM
05-29-2023 09:03 PM
HI @Amanda21
try this trick suggested by CS agent:
Updated 5.26.23 1:55PM EST: Potential workaround (for some): If you don't have access to SMS OTP, try entering an incorrect OTP code 4 times. For some individuals, this is giving the option of an email instead.
05-29-2023 09:02 PM
05-29-2023 09:01 PM
I dont see the options you see
05-29-2023 08:58 PM
Brand new number.
There is no option to send to email. It only sends to phone 😞
05-29-2023 08:57 PM - edited 05-30-2023 11:57 PM
If you have completed the setup of EverSafe ID, you can ask the code to send to email instead
On the screen it is expecting you to enter the code, click Resend code and then choose Send email
05-29-2023 08:55 PM
HI @Amanda21 did you try to port the number? was the port done?
and you can have the code send to email. When it tries to send to your phone, click Resend code and you have choice to send to email
