11-15-2022 11:16 AM
I just new activated my phone 3 day, old number tranfer good for out calling, texting good data ok only receive call is not working, I try so many advice from robot but still not working,what I do ,some one can help me. Out please ,seem like system trouble ?
11-15-2022 02:06 PM
Yes
11-15-2022 11:59 AM
What carrier are you porting from?
A Canadian mobile company?
A Canadian number from a land line?
A Canadian number from a voip carrier?
11-15-2022 11:44 AM
If you can call out and send SMS ONLY that means transfer number did not work properly. What number people see when you call/SMS them?
Did you keep old SIM in a phone and reply Yes within 90 minutes of porting request?
11-15-2022 11:19 AM
Look like the porting was not completed.
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card and can only make outgoing calls, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox. Check the envelope icon on top right. Call them and get it fixed
11-15-2022 11:19 AM
