Activation not working
Jeff16
Hi
I am new to public activated my SIM card an hour ago and my new number is not working.
How long do I have to wait before my phone number will work??
Timer
@Jeff16
you getting new number, so can you call *611.
your credit card is be charges,
tried turn off device and take out SIM card and put it back.
@Jeff16   If it still not working, check if it says "Sim not provisioned" or "No network", it is possible that the sim card wasn't provisioned properly.
You can open a ticket with PM support to have them to re-provision the sim card:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
cc22
Hi Jeff16,
I had the same problem when I activated my Public Mobile SIM card. Not to worry though, give it a few hours and it will work. Like softtech said, if you picked a new number instead of porting it should work. Just give it some time.
@Jeff16   You picked a new number instead of porting, right?
If that is the case, try to reseat the sim card once more.  Power down, take sim out for a minute before you put together and power up again
If still does not work, try to put your PM sim card in another phone and see if it works
