06-16-2019 09:21 AM - edited 01-05-2022 05:24 AM
Hi, I was in the process of activating the SIM card (when through all the screen, picked plan & phone number, added credit card which shows it was charged) but then got the below error. I cannot login with the account I created either and SIM card says invalid now. How can I get this issue resolved? Thx.
Generic Error
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page.
06-17-2019 06:26 PM
Did that, thx for the tip. Hopefully it works out.
06-16-2019 10:08 PM
@kahlonp wrote:The phone has started working with the new SIM now. The account I had attempted to create during activation did not work, so created a new one using the new phone number and PIN it sent. Not sure how the referall would work since I had entered my friend's number during activation which had failed, hopefully both of us receive the credit. Thanks for all your help.
And if you don't receive the credit for referral (10$ for you and 1$ per 30 days for your friend)...write a message to the moderator to let them know!
06-16-2019 09:54 PM
06-16-2019 10:15 AM - edited 06-16-2019 10:19 AM
@alilow I am glad that worked for you, porting takes awhile depending on what type of port you are attempting
06-16-2019 09:42 AM
thx for sharing your experience. Hope my starts working soon to (i did not port any number, just went for a new number)
06-16-2019 09:41 AM
Will give that a try, thx.
06-16-2019 09:39 AM
@kahlonp wrote:Hi, I was in the process of activating the SIM card (when through all the screen, picked plan & phone number, added credit card which shows it was charged) but then got the below error. I cannot login with the account I created either and SIM card says invalid now. How can I get this issue resolved? Thx.
Generic Error
Oh no!
It looks like something went wrong, but don’t panic.Log out and then log back in again to continue. Or return to the Login Page.
This exact same thing happened to me yesterday. I didn't get confirmation of activation or anything. Just generic error and whole afternoon I was re-trying sim to no avail. Then I put in the sim in my phone and lo and behold I have service! Still waiting for number to port over though, so not all is solved for me yet. One step at a a time I guess...
06-16-2019 09:39 AM
It was a new number setup. Will try your suggestion of trying to put in the sim in the phone and rebooting. thx.
06-16-2019 09:33 AM
Thanks for responding, I will leave a message for mods then and hope they can resolve it.
06-16-2019 09:31 AM
Generic Error
Oh no!
Turn off your phone, take out SIM card, waiting 30 seconds or more, put SIM card back, restart your phone.
Clear cookies and caches, waiting one hour, then using incognito mode to log in.
It still don't work then contact moderator team:
06-16-2019 09:26 AM
Did you activate a new number or port a number from another mobile? If your credit card was charged, hopefully the account/phone number is in the process of being set up. Porting a number can take a couple of hours. Put the SIM card in your phone and re-boot to check whether it was activated anyways.
06-16-2019 09:26 AM - edited 06-16-2019 09:28 AM
Generic Error
Oh no!
Because you was charged you will need help from the moderator here...https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 and they will help you. Waiting time is few hours tp 2 days.
