04-07-2023 12:41 PM - edited 04-07-2023 12:46 PM
Hi, I got error 821 while trying to activate my sim. I need a moderator
04-07-2023 04:41 PM
@_Public_ port failed but the account activated??
Please put the PM sim card in a phone and see if you can make outgoing calls. Incoming calls might not work yet, but confirm if incoming works and will advise further
04-07-2023 04:16 PM
This happened to me today, the port failed and they charged my credit card.
04-07-2023 12:56 PM
DO NOT try to re-attempt activation. PM might have charged you already.
Error 821 usually comes up when you request porting and used IMEI as the information for the old provider
First check if PM charge your credit card yet.
Also, put the PM SIM in a phone and check if it connects to PM network and if it can make outgoing calls
If PM has not charge you and the sim card is not connecting, then the activation didn't completed.
You can try to activate again and request porting, but try to enter the account number of the old provider instead of IMEI.
If PM has already charged you, then you need to open ticket with PM support and have them to sort out the activation and porting issue. Since you likely unable to login to My Account yet and open ticket, please open ticket by direct messaging PM support instead
04-07-2023 12:48 PM
How do I PM support?
04-07-2023 12:42 PM
ERROR 821, SIM NOT WORKING
Do not try to activate again! Check your payment card to see if your plan amount has been charged.
Try SIM in some other phone. That will determine if it is your phone’s hardware issue.
Usually 821 is missing/incorrect porting information. Your SIM card will need provisioning to your incomplete account activation. Send a private message to customer support with "incomplete activation" in the subject line and explain in detail your issue. Once the CSA sets it up correctly you will be able to finish your self serve account set up.
