Activation Failing
gargshobhit07
I recently ported my number from Fizz, but the activation on Public Mobile is failing. I’m seeing an “activation failed” message and the eSIM cannot be installed. Could you please help?
gargshobhit07
Can someone from PM help me on this?
gargshobhit07
Yes I received the email with esim. But when I am trying to activate. It is failing with "Activation Error"
@gargshobhit07
Ddi you receive an email with QR code for eSIM?
If not, then you will need to private message CS_Agent
Click on the following link
slusagm
quite many failed activations today.  You need to open ticket with PM.  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
