Activating Sim Email Issue
Ed404
I just tried to activate my sim and it says "The Self Serve username you have entered is not available. Please try again with a different email address". Please help me!
Thanks,
Ed
14 REPLIES 14
Ed404
@totalUser wrote:
Did it go through, can we officially congratulate you?
Thanks for reminding me, I'll go give it a shot. Pls work Smiley Embarassed
Ed404
It looks like it will work, however I went back to double check my email and now I have to 50 minutes to try again. I'll let you guys know if it works.Smiley Frustrated
Ed404
@GR wrote:
@Ed404  if you end up using an alias then just go in your community account settings and change your email to the sane one as your phone and the rewards will go to the phone account
Thanks, I'll try it later if the moderator can't solve my issue speaking to them now.
GR
@Ed404  if you end up using an alias then just go in your community account settings and change your email to the same one as your phone and the rewards will go to the phone account
Ed404
@Dunkman wrote:
@Ed404
Each plan and phone number needs own different email address.
Here is one link to make an alias with gmail:
https://www.lifewire.com/create-gmail-alias-4580315
I've never had a plan with Public Mobile ever! I'll try the alias thing if I don't get any back from the moderators tonight.
Thanks,
Ed
@Ed404
Ed404
@totalUser wrote:
If it was used inn the past and account expired it may be unusable with pm anymore
I also heard it can happen if it is currently used with prepaid koodo
Just try another email address
I've never had an account it wouldn't even let me a month ago. My email isn't part of any account, but it thinks it is. My email is not used with any other provider. What happens to my community rewards then if I use another email? This system isn't perfect I don't want to lose rewards.
Hi @Ed404
Can you maybe change community email instead? You can also notify moderators afterwards to make sure they are linked properly
Ed404
@Dunkman wrote:
@Ed404
That usually means that somebody has used that email address before to set up an account with Public mobile.
Need to choose a different email address or certain email address like gmail can use alias email addresses.
I don't know how to use alias email addresses, I don't really want to either. I tried to make an account a month ago, but my phone number was already in use, maybe it still added my email to their system. I want to receive my community rewards which is associated with the email I just tried using.
Ed404
@totalUser wrote:
What happens if you try to reset password using the same email adress
Tried that I got this "Sorry, we’re unable to verify your email address."
Dunkman
@Ed404
totalUser
Did you use it for another account? Each number o needs separate email address
