Activated wrong Add-on
Ianchik
I activated wrong add-on, I need Canada data instead of US 3gb data. How to change it?
Ianchik
Eventually the situation was resolved by support.
Thanks everyone
@Ianchik   they can likely reverse the transaction and put it back as points on our rewards account.
Please open ticket with support as advised above, and let us know how it turns out
Ianchik
I bought with points. There’s no available funds at the moment. A cancellation would be better option
hairbag1
@Ianchik
go ahead and buy the correct add-on...then ask CSA to credit your account for the incorrect one.
@Ianchik  Please message support to reverse it for you
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
@Ianchik   PM is a prepaid provider and usually no refund
However, if it is an honest mistake, support usually able to do something, please message them directly here:
