Activate from the USA?
urover
I'm currently in the USA and plan to come back to Canada later this year. I want a Canadian number and I don't mind activating a roaming plan from time to time.
A friend will ship the SIM card to me.
I'm wondering if I can activate the SIM from while in the USA?
I have a Canadian credit card, fyi.
Thanks for your help!
@urover
If you are porting an old number then no because you need to reply to the text with the old SIM in your phone.
But if you are picking a new number then it is possible but you will need to purchase a US Roaming plan for it to work.
hycm53
I'm not sure you can activate PM service when you're in USA. You'd better activate it when you come back Canada.
hairbag1
@urover
you should be able to. I would activate a PM sim when you get closer to date when you'll be in Canada.
added...
make sure your cell phone is compatible and unlocked.
