06-04-2024
07:13 PM
06-04-2024
10:44 PM
computergeek541
I just signed up with Public Mobility and purchased the eSIM however, my previous provider delayed porting my number. This was done later and I think as a result the eSIM was not activated. How can I get the eSIM activated without purchasing another?
06-14-2024 10:46 PM
@Luddite thank you. I only use my cell to sign on so I can't do that.
06-14-2024 03:04 PM
Yes, I got a reply I think in 24 hrs. Which is very long when you are trying to solve a problem. It came via both an email and then when I logged into my account, the bell.
06-14-2024 11:50 AM
@Sansan wrote:@JArnold I guess everyone has different profile set up? The only way for me to see messages from cs agents under the avatar. In there is My profile, My settings, My subscription, Message and log out.
Some people get the reply by an envelope (I don't have) or a bell.
Did they reply to you yet?
@Sansan If you reduce font size enough not only does the envelope appear but also all the edit features for replies. On my iPad mini that is 75% while in portrait mode; 85% in landscape. 🙈
06-05-2024 03:07 PM
Great
06-05-2024 02:55 PM
Thank you! Everything works now. What an ordeal though.
06-05-2024 02:08 PM
HI @Sansan
Envelope or under My Avatar depends on mobile browser or regular browser. And even regular browser , if the browser windows not wide enough, the envelope icon will still be "gone"
06-05-2024 01:56 PM
06-05-2024 10:07 AM
HI @JArnold
if you see the envelop besides the avatar, you can simply click on the envelope
or you can use this link to access the inbox
06-05-2024 09:30 AM
Hi Sansan,
What do you mean by "click on my avatar" and messages for their reply? Under my Avatar there is only "Settings" "Profile" "Subscriptions". I sent a message to a CS Agent. Do they reply in the same area as this conversation?
06-04-2024 08:17 PM
Ok sorry. They will fix for you. Just click on your avatar and messages for their reply. I believe they close at 9pm so probably tomorrow morning.
06-04-2024 08:00 PM
Hi Sansan,
I tried all the ideas you gave. Nothing worked. I've submitted a ticket. I think they need to go in and activate the eSIM. I don't think I can do it because it just asks me to purchase and activate a new one. I've already paid for the first and don't want to do that.
I also tried the link you sent and it didn't have anything to match all the things I asked. I guess I'll wait on a reply to the ticket.
06-04-2024 07:28 PM - edited 06-04-2024 07:30 PM
@JArnold did you receive the email with the qr code?
Also check your sim manger if esim is there and turn on this line or make it primary.
You can start by reboot phone. If that doesn't work, reset networks.
If you still cannot get it going, once signed into your account, use the chatbot to submit a ticket.
Or link below.
