Acer Liquid Zest Model T08 - Is this phone model compatible
4nakmin
Data is not working and online help is asking if this model is compatible, not showing up in list.
@4nakmin
Does talk and text work?
You could try a network reset.
Check the APN settings:
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
ShawnC13
My wife used the Liquid Zest on PM a few years ago.  Now not sure exactly what model it was but it worked here.
Dunkman
@4nakmin
This phone does have the necessary 3G bands for Pubic mobile (850, 1900).  Might not have the necessary 4G bands.  Talk and text should work fine. Data might be slower.
Here are the specs for your phone:
https://www.gsmarena.com/acer_liquid_zest-7955.php
gpixel
@4nakmin change your preferred network type to 3g, I'm not sure if this phone supports the LTE frequencies for public mobile
