06-12-2026 09:01 PM
Hello, please confirm I will no longer be charged with Public mobile as I switched to another phone carrier. It should have automatically cancelled but please confirm here.
06-12-2026 09:11 PM
if your number was ported successfully, then the account was no doubt closed already
but you can still make sure PM removed your credit card from the system completed. Just open them a ticket. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
06-12-2026 09:09 PM
additionally; try dialing 611 to find if your acct is still accessible. If not, it's been deactivated...no further payments to be charged.
06-12-2026 09:09 PM
@liv55555 wrote:Hello, please confirm I will no longer be charged with Public mobile as I switched to another phone carrier. It should have automatically cancelled but please confirm here.
Hello @liv55555
Once you port your number to another service provider, it automatically closes your account with Public Mobile. If your Public Mobile SIM card no longer works, that is a 100% confirmation your account is closed. If that is happening, no need to contact customer service. Only reason to contact customer service is if the SIM card is still active.
06-12-2026 09:04 PM
first, we are just customers here
but you can check by trying to login to your My Account. If you are able to login, then the account have closed and hence PM won't charge you again
if you want to be sure, you can submit a ticket with PM CS agent. open ticket with PM by private message CS Agent using this link:
**Monitor the Community inbox (envelope icon on top right) after ticket submitted, CS Agent will reply there
