Account
Omgwow
Why is my phone number not linked with my account anymore just because I switched to a new phone
@Omgwow
If your old phone is on eSIM. You can’t transfer the eSIM. You need to download the PM app on the new phone and login to your account and make a purchase a new eSIM.
It is much easier if your old phone is on a SIM. Just pop it out of the old phone and put it into the new phone and reboot the phone.
hi @Omgwow it should not be the case
try again using both app and browser.  If same, ask support to help , you can submit by direct message:
Phil_Adelphus
@Omgwow  Did you move the physical sim from the old phone to the new one?  Or are you using esim?
