Account
Subarlou57
I was charged for 2 plans in August. I need a refund
Subarlou57
Public sold me plan that does not work on my phone.  I want a refund. Or a months credit.
DDM69
Post a screenshot.  You haven't provided enough details.
NDesai
@Subarlou57 What are the dates and amount? As mentioned above, if you did a plan change immediately, you get charged for the new plan right away.
@Subarlou57
did you make any plan change request in August?  if you did, did you use "Change Now" option?  if you used that, PM will charge you new plan immediately and no partial reufnd with the unused days on the old plan
Or did PM charged you on August 1st as well as August 31st, if that is the case, it is normal as PM is running on 30 days cycle and not monthly
If PM really charged you twice and it didn't make sense, open ticket with PM support, message them here:
@Subarlou57  Did you change plans by any chance and do it immediately and not in renewal if so that could be the reason . Also check that one charge isn’t just pending if so it should fall off but if both charges are posted then please submit ticket with support  for credit /refund
send a  private message   To CS_Agents click
