Account subscription plan change
Jen301
The requested online change seems to be on a permanent holding pattern. Is there an alternative method to process this change?
7 REPLIES 7
Jen301
Thanks for your concern. Solved the problem by selecting the other option on changing the highlighted subscription plan.
@Jen301  We happy to hear you got it all sorted out 🙂
Jen301
Thanks for your response. Decided to select the other option instead of waiting. No problem here.
Jen301
Never mind. Found the way around the problem. Just selected the other option.
Yummy
What are you trying to say? What change, what hold?????
@Jen301  .this sis second post today about not being able to change plan immediately . Thinking there may be issues with the site right now . Maybe try again in a hour
@Jen301 what do you meant by that? you meant you do want automatic payments?
