Account setup issue
Scottdoug
Is there a technical support available? Having an issue with account set up
Fatima079
I just set up mine - kept my old active sim in my phone, downloaded the Public Mobile app, followed instructions, chose "existing number" to port my old number (had to find my account number with the other provider I was with), and then it told me to keep the app open for 2 mins and don't minimize. Then, a text came up from my old provider asking me to confirm the port and...then I removed the old SIM and put in the PM one. Voila it seemed to work.
ORNGNBLK
Further to @cellphoneuser1 s suggestion here’s a link to send  a  private message   To CS_Agent
cellphoneuser1
What type of issue is it?  To finish setting up your account, the Public Mobile app has to be used. The website won't work to finish activation.  If it's an issue that you can't fix yourself, send private message to CS_Agent.
ORNGNBLK
@Scottdoug which step are you at?
have you already downloaded the public mobile app? It should be straightforward from there, but please let us know where you are and what issues you’re facing
