05-02-2025 05:53 PM
Just setup my account and picked a phone number and the last step to activate account seems to be sending me SMS on a number which is not quite set up yet.
How do I get out of this bottom less pit or the catch 22 scenario
05-02-2025 06:27 PM
The phone was probably hung up in some weird state ... I simply put into plane mode and then off the plane mode and texts started flowing ... All hooked up now ... Cheers
05-02-2025 06:02 PM
@CrustyI wrote:Just setup my account and picked a phone number and the last step to activate account seems to be sending me SMS on a number which is not quite set up yet.
Hi @CrustyI
There should be something there that says... "Didn't Get Code?" and if you click on it, it should give you an option to send to email. If that option isn't there, then please create a ticket.
The Public Mobile chatbot is currently unable to create trackable tickets for members who are unable to log in. So for this reason, please use the following link to contact them.
