Account locked
08-26-2020 11:33 AM - edited 01-05-2022 12:56 PM
I've been locked out of my account. I failed to answer my security question to change my password. What should I do now?
Thanks!
My Account
08-27-2020 11:56 AM
Contact moderators: click the "?" in lower right side of the page, type "contact moderator", and follow directions, OR send a message: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
08-26-2020 11:47 AM - edited 08-26-2020 11:48 AM
Create a moderator support ticket for help using this link https://publicmobile.ca.ada.support/chat/
Tell SIMon what is the issue (important) - "Forget password and security question"
Use this magic phrase which SIMon recognize to let you create a support ticket quickly.
After submitted a ticket, members should check their private message SENT folder for their ticket which they just created.
If you cannot find your ticket in your SENT box, You did not create your support ticket yet. Also monitor your INBOX for any reply from moderator.
Click the envelop icon at the top right corner to access your private message mailbox.
08-26-2020 11:38 AM
Your would need to submit a ticket to a moderator by clicking on the question mark question mark on the bottom right corner.
08-26-2020 11:34 AM
Bonjour @deepg82 Contact the moderators and ask them for a temporary password to your self service account. There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
