09-16-2022 06:35 PM
09-16-2022 08:28 PM
@Alikatt80 If need to make a payment, then top up your account by purchasing a voucher from SDM, London Drugs, 7/11 or Shell and then dial 611 on your phone to add the funds without the need for a PIN.
09-16-2022 07:03 PM - edited 09-16-2022 07:04 PM
@Alikatt80 wrote:
- Hi I need to change my account pin that u would put in order to add phone mins
@hTideFnow , what 'other pin' are you referring to for opening a ticket?
edit..and @Alikatt80 was this the same issue you had before, or is it a totally different one?
Here is your other post: https://productioncommunity.publicmobile.ca/t5/Get-Support/Forgot-my-pin/m-p/851740/highlight/true#M...
09-16-2022 06:45 PM
Login go to profile there change 4 digit pin
for other pin you need , open a ticket with PM CS_Agent. at : https://publicmobile.ca/chatbot.
type: Contact Us and Other
Finally Click here to submit a ticket
If you have error submitting a ticket, send a private message to the CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
check inbox(top right corner envelope icon) for response from CS_Agent.
09-16-2022 06:39 PM
hmm which pin? What mins? What are trying to do? Can you login to your account?
