4 hours ago
ive transferred from fido to public and my phone number is stuck on my first sim and my esim doesn’t show i have data or a phone number despite it working. My imessages and other phone number lines aren’t registering. Any fix to this? i’ve reset my netowkr
3 hours ago
remove the physical sim , reboot and check if the esim works. Make sure after the reboot, the esim is set to Primary and Turn on this line is set on the phone
3 hours ago
@Anthony2003 , can you try removing the p-SIM and setting the e-SIM as active, see if that helps. I assumed you did receive a number transfer verification text to your p-SIM and you confirmed it.
4 hours ago
more details: i had a physical sim and apple sees my physical sim with my phone number instead of esim. I’m receiving texts to my number but i can’t send through my imessages and have to send in sms.
