Account access and refund
Yukyeong
Hi. This is Yukyeong xx. Actually, I made a new account ([email protected]) last time and I purchase a plan and I paid. I tried to transfer my number from Fido that I used to use before and also wanted to get a E-sim. But I couldn't get access my account and digit number through my previous number.
I was in a hurry to use it, so I just made the other account ([email protected]) and paid one more time and changed my number not a transfering. Finally, I m successfully using it. But I paid twice.
I wanna get a refund about this account ([email protected]) and get rid of it. I still can't access my account and I m having a difficulty for getting answer several times.
Please contact me as soon as possible.
Thank you,
Yukyeong xx
Kong2
I tried to contact thousand times but always said log in and cancel but I can't get access log in at all. cos I couldn't confirm my identity cos I couldn't get any digit code through the my  number.
fixin1
@Yukyeong - For the issue, I would refer you to CS_Agent:
⬇️Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST.  You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
Dunkman
@Yukyeong
You will need to submit a ticket for customer service agent help.  The wait times are longer these days.  You can submit a ticket via the chatbot or via the following link:
I will need to remove your personal information from the public forum.
