Account Number
precollet219
How do i find what my account number is ?
Tsawwassen
It's your email.
@precollet219 wrote:
For some reason I cannot login. I have reset the password and everything.
@precollet219   Reset password and login using Incognito mode and see if it works
If not, you might want to open ticket with PM support to get access to account back:
If you are unable to self reset the password, PM support will be able to help
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
pkaraa
So you know about going to profile and find the account number ...
reset password working? if the password has been reset and still it is not accepted at login screen, create a ticket.
Hollister
@precollet219
Clear your browser cache and go incognito.
precollet219
@precollet219   login to your My Account and account number is on the Profile page:
https://selfserve.publicmobile.ca/en/account/my-profilehttps://selfserve.publicmobile.ca/en/account/my-profile
