12-04-2022
07:22 PM
12-04-2022
07:43 PM
computergeek541
12-04-2022 08:02 PM
Yes. Just send YES2 to 4911 short code and you will get a reply saying that PM added the free add-ons to your account.
BTW, I sent YES2 to short code 4911 without receiving the offer SMS. PM will reply"Looks like not eligible for this offer.
12-04-2022 07:55 PM
@HALIMACS wrote:
Just try it, then log into your self-serve to see if the bonus items are added to your Data & Add-On's section.
Make sure to clear cache and cookies and open an incognito tab before logging in to get a non-cached version of the site.
Thats easier said than done if you are not tracking them!! Because PM does not date them in your My Account. Do you know how many duplicates and triples some people have? Maybe I should offer an excel tracking program for those that want to be in control of their account(s).
12-04-2022 07:35 PM
12-04-2022 07:34 PM
12-04-2022 07:34 PM
Yes, if you're sure that you got that text sent to you already,. Then definitely send YES2 to 4911 and you should get those gifts right away. Enjoy them.
12-04-2022 07:25 PM
Yes.
If the invite was sent....you will receive an immediate response of your freebies.
If another message ....you will have to keep trying. .
12-04-2022 07:24 PM
@fridgecs if you got text already , then yes, sending YES2 to 4911 will work
if you have not received it yet, then sending YES2 early won't work
