12-04-2022 06:46 PM
I cannot get into my account to change my plan because I do not have that email no more.
12-04-2022 06:53 PM
You don't need to have the e-mail active - you just need to know the e-mail address. It's just a username.
If you remember it, enter it in the username field, then enter the password.
If you forget either of the above pieces of information, then yes, you'll then need a Customer Support Agent to amend the registered e-mail address to a current one you use.
12-04-2022 06:49 PM - edited 12-04-2022 06:50 PM
You'll have to get your email address updated for your account with help from a CSA from Public Mobile.
Get CSA by either by using the Chat Bot Simon to get a service ticket or send a private message to CS_Agent
12-04-2022 06:48 PM
Contact an agent.
During business hours, we strive to answer customer messages swiftly. You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in top right hand corner for a reply from the agent.
