09-17-2022
11:11 PM
09-17-2022
11:25 PM
computergeek541
To whom it may concern,
I made the mistake of buying talking in the US believing it had data and was wondering if it was possible of getting a refund. I haven't and don't plan to use the US minutes. Please advise.
Sincerely,
-Amanda
Add-Ons
09-17-2022 11:22 PM
@aleeyow PM. is a prepaid provider and usually do not provide refund. However there are also very understand and will help in honest mistake like that. Open a ticket with PM support and discuss with them the situation and see if they can exchange you for another addon or put it back as a credit on your account.
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
09-17-2022 11:21 PM
You would need to address that to the support people. Click on the chatbot link down below and find your way to submit a ticket.
It's all roaming by the way. Roam talk, roam text, roam data.
