12-17-2021 04:30 PM - edited 01-04-2022 04:55 AM
Hi there,
Hoping you can help. I have 3 accounts with Public Mobile and the corresponding emails for each are no longer valid. I need to access the accounts so I may update my auto-pay information as my existing credit card information has expired.
How can I gain access when the "password reset" function will not work as the email for this is no longer valid.
12-17-2021 04:42 PM
Click on the chat bubble at the bottom right corner of your screen and type "password reset" and "human" and follow the prompts to submit your ticket via Simple--Simon. Keep an eye on the envelope icon at the top right corner of your screen next to your avatar for a little number to pop up indicating a reply from a CSA. Responding promptly will speed up service times but replies are less than one hour currently,
12-17-2021 04:37 PM
@manhas44 wrote:Hi there,
You'll need to ask Customer support to that for you, using one of these 2 methods:
Open a ticket via:
https://widget.telus.tiia.ai/publicmobile/publicmobile.html (faster response time)
Type "ticket" > Click "Contact Us" > Select your issue > "Click here to submit a ticket↗"
or send a private message to:
and describe your issue. Include your name,phone #, account #, Email address,4-digit PIN to speed up authentication process.
After sending the message, watch your community inbox for their reply.
12-17-2021 04:36 PM
Here’s when and how to contact our Customer Support Agents:
12-17-2021 04:33 PM - edited 12-17-2021 04:34 PM
To change the email address, you will have to contact PM support and they can update the email address for you, use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Forgot Log in Information ", click "Contact Us", click "Click here to submit a ticket". Then follow to complete the ticket submission.
Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
12-17-2021 04:31 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
and them will change for you,
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck....
