About data
Red_Gurl
Was just wondering why my data usage is climbing when I've been connected to wifi??
Mattredwingsfan
@Red_Gurl
you can also use the following steps to Monitor/Control your data
if your are using an iPhone
Disable apps auto update
  • iTunes & App Stores > Turn Off Use Cellular / Mobile Data
Disable background data
  • Go to Settings > General > Background App Refresh > Turn it Off entirely or by selective Apps
Disable iCloud sync
  • Go to Settings > Cellular / Mobile Data > Turn Off iCloud Drive
Disable Wifi Assist
  • Go to Settings > Cellular / Mobile Data > scroll to bottom > Wi-Fi Assist > turn OFF
Disable data on certain apps
  • Go to Settings > Cellular > Scroll through and disable applications you don't want to used your Cellular Data
Hope this helps
Cheers,
Triguy
Make sure you disable auto updates for apps and turn off GPS.  You can log into your account to see your usage history.
Hi @Red_Gurl ,
A good practice would be to toggle off your Data when in wifi areas.
Certain apps can use Data depending on your settings on that app even in wifi areas.
Managing Your Data Usage:
https://www.publicmobile.ca/en/bc/get-help/articles/managing-your-data-usage
iliketotalk
@Red_Gurl hi check to see if you have wi fi assist turned on if so turn it off how much data are we talking about?
