Precedence of Long-Distance Minutes Add-ons
latefordinner
If I purchase the "500 Canada-wide Long Distance minutes" and "200 U.S. & Canada Long Distance minutes" add-ons, will the 500 Canada-wide minutes take precedence over the 200 minutes for Canadian numbers?
latefordinner
@Anonymous I'm very glad there is a great community to get answers from.  But sometimes people need a gentle reminder that it's not good enough to just spam a random answer.
Well I'll have a go.
Yes.
You can have plan minutes, 500, 200, 400. It consumes in that order calling Canada.
Edit: no need to jump on anybody. We're all fellow customer like you just trying to help out a little.
dabr
@latefordinner   Yes the domestic add-on minutes are used first, after depleting your plan mins, and if you've used up all your domestic mins before adding anymore/renewal resets your plan, then the 200 US/Canada mins would be used.
latefordinner
@Triguy Did you bother to actually read my question?
Triguy
Your plan minutes are used first then the add-ons would be used.  They remain in your account until used up.
benfatto
Based on my experience it does. Easy enough to check In your self serve account though as soon as your regular minutes have been used.
