About Rewards
02-29-2024 11:16 AM
I was wondering about the reward system will be keep same(old reward system) if change to different plan?
Rewards
02-29-2024 01:30 PM
Thanks all guys
02-29-2024 11:41 AM
Can confirm what the others here are saying. I recently switched plans and my old (much better lol) rewards are still intact. What a relief 😊
02-29-2024 11:26 AM
Yes as rewards are tied up with your account Not plan.
They only way to get points is if YOU switch to them...
02-29-2024 11:20 AM
HI @Way1
we all agree that the legacy is much much better then points
main difference is the loyalty rewards, you can get as much as $5 off per month after 5 years being here, that's $60/year!! with points, no mater how long you are with PM, you only get 10 points for Anniversary
02-29-2024 11:17 AM
you'll stay on Rewards when you change plans....just never opt for Points..ever !
02-29-2024 11:17 AM
Yes you will. Changing plans not affected
