Error installing esim
NDA2
Hi,
I’m trying to set up an account and port in my number from Koodo. The process keeps failing when trying to install the eSIM, saying it’s incorrect.
Can someone please help me with this?
Thanks
@NDA2
open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
NDA2
Thanks, but there is no esim installed. I need them to push it to my phone again. Who do I contact for that?
Sansan
Is your koodo account pre-paid?
If you are transferring from a Koodo prepaid plan, you will need to select a new number and then send a private message to the below to complete the transfer to Public Mobile.
@NDA2
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android:  Check your Sim Card Manager and see if a Public Mobile eSim is there.  If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there.  If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually.  If you cannot find it in Inbox of your email, check also the Spam box.
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it.  If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
If it still does not work, open ticket with PM by private message CS Agent using this link:
**Monitor the Community inbox (envelope icon on top right) after ticket submitted, CS Agent will reply there
