04-19-2023 07:41 PM
So I looked up the APN setting for iPhone in the Help section, it says that it should be:
SP.MB.com
The current setting on my phone is currently isp.mb.com.
I had had very little issues with cellular data until the last couple of days, a shutdown plus 5 min wait and restart did solve the issue, but I'm just wondering if I should change the APN setting to sp.mb.com ??
04-19-2023 08:00 PM - edited 04-19-2023 08:00 PM
@chad2001 one more thing to check, make sure Carrier profile is updated
Go to Settings and then select More and Mobile Networks, now select Carrier Settings and then Update Profile,
04-19-2023 07:54 PM
If it works I wouldn't worry about. I have 3 different phones I use on pm and all have slight differences in their APN's.
04-19-2023 07:53 PM - edited 04-19-2023 07:54 PM
@chad2001 wrote:So I looked up the APN setting for iPhone in the Help section, it says that it should be:
SP.MB.com
My iPhone 8 Plus APN setting is isp.mb.com too. But I didn't have any issues.
You could try reset network setting.
