APN locked, greyed out
phflupp
I cannot edit the APN on my Asus Zenfone 3 (Android) because the menu is locked (by Public Mobile?) so I cannot make the changes your recent email require.
Please advise.
2 REPLIES 2
@phflupp
can you Add a new APN profile?  Usually is a + on the top right
and another common trick people uses is to use a Freedom sim card and that can open the APN add/edit feature.  Try to borrow a Freedom sim from friend
Chalupa_Batman
Hey. I read this on Reddit.
Try this:
  1. Dial ##data# in the phone app.
  2. Tap APN Settings
  3. Tap 3 dots > Reset to default
  4. Reboot
Someone else mentioned about toggling it into airplane mode, waiting a minute, untoggle then reboot. Then it appeared.
If that doesn't work, try reaching out to a CS Agent for ideas.
There is also a GIANT thread on this phone here.
Calls work. No Data. Cannot edit/add APN. "Automat... - Community (publicmobile.ca)
