09-16-2016 10:00 AM - edited 01-04-2022 01:01 PM
Samsung Note 2 unlocked. When I tried to add APN under mobile networks, the default mcc shown is 310. I can't save it as 302. After I change it to 302 and save, the public mobile APN will disappear. I can save changes for all fields (proxy port etc) except MCC.
Does anyone know how to fix this???
Thanks in advance.
09-20-2016 09:31 AM
@imm1304 indeed, though consistent with the T-mobile that the card seems to inexplicably be locked to! Very very strange indeed....
09-18-2016 11:57 AM
Hi again @pxszycan!
This is highly unusual problem. Area code 267 is in Pennsylvania,US.. well outside the PM jurisdiction or coverage area.
Anyways, I hope that transferring your account to the new sim card will fix this. Would love to hear an update once you have the sim card. Good luck.
09-16-2016 03:12 PM
Thanks!!!!!!!!!
09-16-2016 03:08 PM
@pxszycan that's really weird! I've never heard of a factory reset somehow corrupting a previously correctly functioning SIM card, but it appears that's what has happened to you. 😞 Hopefully replacing your card will resolve the issue. I wish you good luck, and hope you will keep us posted after receiving the replacement.
09-16-2016 02:06 PM - edited 09-16-2016 03:12 PM
Thanks!Believe it or not, this not a new sim card. It was working fine for 6 month! Until I did a reset on my phone yesterday! Originally I thought it's a android software issue, I reset the phone again, didn't work. Today I tried the sim card with a new phone and it still didn't work. That's when I start to feel problem is caused by sim card. However, I don't understand how a phone reset could permanently change MCC and MNC setting stored in a sim card? Is that even possible?
Just an updated. My just found out the phone # assigned to my sim has changed to something else! How weird! My # has always been 647******5, now it shows 267******3.... full signal bar, but can't register on network.
09-16-2016 01:56 PM
Hey @pxszycan
Please don't hesitate to send me a private message with your complete shipping address. I'll be able to order a new SIM card for 🙂
Mary
09-16-2016 01:25 PM
@pxszycan if you're getting the same result in another unlocked phone, I think it must be the SIM card somehow. I'm assuming you have never successfully used this particular SIM card in the past and you are activating a new service? I think you may need to get a replacement SIM card unfortunately. I'm going to suggest that you private message @Mary_M and @Shazia_K with your situation and your shipping address and ask them to send you a new SIM card to try to resolve the issue.
09-16-2016 12:32 PM
Deleted T-Mobile profile and tried to add Public Mobile as new. Samething, default MMC 310 MNC 260. I changed them to 302 and 220. As soon as I hit save, the entire APN entry disappears. I can only save the entry with default 310/260 settings. Any changes to MMC and MNC cannot be saved......
I start to wonder is the MMC MNC setting saved in the SIM card or the phone?? So I tried the pm sim card in an unclocked NOTE4. Exactly the same thing! Default MMC310 MNC 260!
Does anyone know how to change this??? Thanks in advance.
Btw, I've tried to factory reset Note 2 # of times with Samsung Kies. That doesn't fix this issue.
09-16-2016 12:26 PM
My note 2 was originally from Rogers. Unlocked after contract is over. I tried "restore defaults", and T-Mobile US is what I get after the restore.
09-16-2016 10:59 AM
09-16-2016 10:56 AM - edited 09-16-2016 10:59 AM
Hi @pxszycan!
Your Note 2 must have originally come from T-Mobile USA.
Public Mobile sim cards can't possibly be locked to T-mobile as that would be suicidal on PM's part.
On the APN settings page, tap the 3-dots menu and select "Restore defaults"
Then, tap the same menu button and select "Add APN" and enter fresh APN settings specific to PM as shown here: http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/How-do-I-setup-data-and-APN-on-my-Andr...
Save the new PM APN and select it. A green dot should show next to these newly entered PM settings.
09-16-2016 10:27 AM
Just tired did a factory reset on Note2, same thing...
Forgot to mention, the default APN when inserting public mobile sim card is "T-Mobile US". Below are the settings.
Name- T-Mobile US
APN: epc.tmobile.com
Proxy: not set
Port: not set
Username: not set
Password: not set
server: not set
MMSC: http://mms.msg.eng.t-mobile.com/mms.wapenc
Multimedia message proxy: not set
Mutimedia message port: not set
MCC: 310
MNC: 260
APN type: default, supl,mms,mms2
I tried to change MCC under T-Mobile, as soon as I hit "save change", the entire APN disappears. Looks like the sim card is locked to MMC310 MNC260 some how...... Any one knows how to change this???
