11-01-2024 03:46 PM
I am setting up a new service and the code is being sent to an unknown number. How do I change the number to receive a code
Service
11-01-2024 08:12 PM
That’s the part I made an error, I entered the wrong number, now the code is going to that number but it’s not my phone. I need to know how to change the number to put the correct one in
11-01-2024 04:30 PM
Did you port your number over from another carrier?
If you did, you need to reply with YES to confirm you are porting over to PM with the old SIM in your phone. Your old carrier account must be active to port your number over.
11-01-2024 03:49 PM
hi @Sandra50
you will need support to sort this out . Message them
