06-02-2024
09:36 PM
06-09-2024
10:54 AM
Dunkman
I've use public for 3 years and this problem has started happening recently. I managed to fix it because I have a phone that lets me change the APN so I decided to change it and after constantly changing it back and forth it finally stayed on Alberta instead of Quebec because Quebec has YouTube blocked. My picture messaging works now, but my mom and cousin are having the same issue. But there not tech savvy like me any ways to simple fix it I took the tech savvy route because I am tech savvy but any ways to do it simply
I use a Ulefone Armor X6 Pro
My mom uses a Ulefone X13 I don't know if it's pro
My cousin uses a Ulefone Armor X6
Anyone have any ways to fix it simply
06-02-2024 10:39 PM
HI @Moppie
and if MMS still does not work , maybe better to use app to send multimedia, like Whatsapp
06-02-2024 09:59 PM
I just looked up the APN settings and added a new APN setting and put the info in there
06-02-2024 09:58 PM
My GID type sets to 4D4F is that a big difference
06-02-2024 09:57 PM
@Moppie wrote:Kimovl.ca says it's perfectly suppose to work in Canada type in Ulefone X13 and Ulefone Armor X6
yes, the phone itself works, but just little things like this and hence phones not designed to Canadian market might not work perfectly.
The phone's ROM has some APN info for worldwide provider and it likely does not have the correct APN settings for Public Mobile there. Somehow the phone always get that APN from its rom instead of the one you added yourself. it is a phone issue and it might or might not work.
Again, your phone should work most the time , but little things there and there. And since it is not a phone for Canadian market, it might miss couple necessary network bands for PM as well, and hence you might see some connection issue sometimes, in some area
06-02-2024 09:53 PM
06-02-2024 09:53 PM
HI @Moppie
did you use add new instead of update the old one?
and make sure you save properly (look silly, but some came back and said it didn't save the first time and hence it took time mutliple times to get it working)
06-02-2024 09:51 PM
I did that I had to switch like 5-10 times and my mom and cousin won't remember to do that I want a simple way to fix it
06-02-2024 09:41 PM
HI @Moppie
they are not a phone designed for Canada and hence it needs manual APN update
You really need something who has experience with Android phone and ask the person to help them to create a new APN profile (create new and not just update the current one)
You probably have the full APN settings, but here is one just in case:
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
