02-22-2017 11:54 AM - edited 01-04-2022 01:32 PM
Hey Public Mobile,
I have topped up my account automatically via credit card and I have no data, it has been 6 days now, I even paid again to leave an extra amount of money in my account and nothing has changed. I have done all troubleshooting on my iphone 6 and nothing has changed from that end either. I need a MOD/PM Customer Service to fix the problem. I paid for something that I cannot use.
And also, I am not sure if it is just me or other people are experiencing the same issue but when I try to contact public mobile direct without posting on the communitiy board, the page doesn't load??? I've tried 3 different browsers.
02-23-2017 04:50 PM
Farhad wrote:My aplogies for wasting your time but the site doesn't show anything and I also got this account confused with another one I had which was working fine! Sorry about that.
Not really your fault - this is a flaw in the self-service portal that PM is apparently working on addressing.
02-23-2017 04:39 PM
@Shazia_K wrote:Hello @Farhad,
Thank you for sending the info, after taking a look at your account, I see that you have used up all of the data allowances for this billing cycle.
You need to wait until March the 8th in order for your plan to renew.
Thank you,
Shazia
02-23-2017 11:57 AM
@WearySky I hear ya! @Saray_O did indicate about a week or so ago that PM is working on changing that. I have no idea what the timeline might be, so we have to be patient for now while it continues to cause confusion. Welcome to Public Mobile! 😉
02-23-2017 09:54 AM
The lack of messaging in the self service portal to tell people that their data is all used up strikes again! *shakes fist angrily*
02-23-2017 09:51 AM
Hello @Farhad,
Thank you,
Shazia
02-22-2017 08:08 PM
@WearySky wrote:
What do you mean by "contact public mobile direct" - do you mean the "Contact Us" form? IMO, if you've already got a forums account it's FAR better to send the mods a private message directly. The "contact us" form seems to have significant issues at the moment.
Yes that is what I was talking about thanks!
02-22-2017 08:07 PM
I'm truly sorry to hear about this,
I did receive your private message but you forgot to include your Public Mobile phone number or account number.
In order to better assist you, can you please send me the missing information?
Thanks,
Shazia
Hi Shazia,
I have sent the information you requested. Thank you.
02-22-2017 07:49 PM
@Acekiller wrote:This may sound stupid, but check your APN settings, and reboot your phone while you wait for the MODs.
Tried that no success.
02-22-2017 07:49 PM
@will13am wrote:If calling and texting still work, can it be that a phone setting was accidentally changed that is blocking data? Check to make sure mobile data is enabled, the user set data usage limit has not been exceeded. I had a friend who crippled her data connection this way. She put the data limit at 4 gigs to even out the usage. One month, usage exceeded 4 gigs and data stopped. Anyway she's set the data limit a lot higher and put the warning at 4 gigs.
It's not that, I am not using any apps or iphone default settings to restrict data.
02-22-2017 06:36 PM
@CaNuCk07 wrote:@Acekiller not stupid at all, sometimes updates can mess with apn settings, and hard restarts sometimes are what you need.
@CaNuCk07 @Acekiller actually another thing to check at least on Android phones if if you've accidentally turned off mobile data. I've done this a few times and it takes a little bit to realize what I've done. If you tap on the mobile network icon in your quick settings pulldown, most Android phones toggle the mobile data on or off. And it's fairly easy to tap on that by accident when you're trying to scroll or dismiss the notification/settings pane, for example.
02-22-2017 04:02 PM
Hi. It meant either Emailing or sending a PM Mod a Private Message.
Rest assured, You are in great and soft hands, @Shazia_K will help get you back on your data, and with success
02-22-2017 03:25 PM
02-22-2017 02:53 PM
Hello @Farhad,
Thanks,
Shazia
02-22-2017 01:19 PM
02-22-2017 01:15 PM
02-22-2017 01:07 PM
02-22-2017 12:54 PM
@Farhad when you login to self serve do you still see Data listed? Might ahve been a glitch and dropped it but if you have messaged Shazia no worries she will get you all fixed up
02-22-2017 12:32 PM
@imm1304 wrote:Hey @Farhad,
Include your public mobile phone number in the private message to the mods. It will help them locate your account and speed up the time it takes to fix this. I look forward to hearing that this was resolved today.
I have PM'ed @Shazia_K just waiting for her response. I hope its resolved today.
02-22-2017 12:27 PM
Hey @Farhad,
02-22-2017 12:07 PM
02-22-2017 11:58 AM
Best way to conctact a moderator is to tage them here @Shazia_K, or follow the below to send them a private message, which is probably the best way to get your problem resolved.
02-22-2017 11:58 AM
Calling and texting works. I just renewed my plan, I am on the $120 plan for 3 months. 12GB data.
02-22-2017 11:56 AM
@Farhad As of right now there aren't any reported service outages.
Have you checked your usage to ensure you haven't used up all your data for the period? Is your calling and texting working?
